NWA210AX and NWA50AX working together
Good morning,
I have one house with a bottom and top floor with one AP (NWA50AX) in a room over the garage and the other AP (NWA210AX) on the second floor, I have a total of 70 wireless devices in my home. I have them both installed in Nebula but I'm having a difficult time trying to get both to work like a team. I don't think I can use load balancing in my configuration due to NWA50ax does not support it, correct? The AP's are about 15ft away from each other, but I'm still getting channel congestion and can't seem to get the sweetie spot configuration. Please advise. Thank You.
Hi @Bishop527 ,
You're right, the NWA50AX doesn't support the Load Balancing feature. However, you can configure this feature on Nebula, and the settings will be applied to the NWA210AX.
For improving wireless network performance and reducing channel utilization, you can refer to the recommendations provided here. If the issue persists, please enable Zyxel support and provide us with the name of your Nebula organization/site here or via the private message by clinking to my account > Message.
Zyxel_Judy
Hi @Bishop527 ,
Zyxel_Judy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
