500H - Error while DDNS updating
Hello, can I have an answer please? We need this feature to work fully!
To temporarly fix the problem, I have to change something in the "failover" profile and save. After that, the profile works as expected
Hi @Mk88_it,
I apologize for the delayed reply. Could you share the configuration of the issue with us so we can compare the differences? We also checked the previous configuration file. Is the "HTTPs" option the difference between the issue and the no-issue configuration?
Zyxel Melen0 -
Hello @Zyxel_Melen, I sent a private message to you about that
Hi @Zyxel_Melen the ddns issue still persists even with 1.32 firmware
To solve the issue, i must edit the profile changing something, save the profile and then It works for a while or until next reboot.
Update:
This issue has been addressed on V1.32 and will be fixed in the next firmware release.
Zyxel Melen1
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 500 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
