Is it possible to import static DHCP into EX3600-T0
Goose4
in Home Router
Is it possible to import static DHCP into EX3600-T0?
Getting a new ISP and want to try their router, so how can I transfer static IPs to the Zyxel?
best regards,
G
for static IP on LAN, you can go to Home Network —> LAN setup, then you can set up static IP address for LAN access.
Thanks for the answer.
But it doesnt answer the question:
Will I have to manually enter all IPs or can can I import a liste info the router?
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
