Disable SIP ALG
Hi there, for days and days i am trying to disable sip alg from interface of my EX3501-T0 router but i couldnt find the settings of it. My sip phone doesnt work otherwise. Please give ideas
You can find the ALG section in the Network setting /NAT menu of your Network .
BUt when you have a restricted firmware ISP Router you may not find this section…
Unfortunately, finding the exact steps to disable SIP ALG on your specific EX3501-T0 router can be tricky as router interfaces vary between manufacturers and even firmware versions. However, here's a general approach and some ideas based on common router settings and the search results:General Steps to Find SIP ALG Settings:
Access Your Router's Configuration Page:
Open a web browser on a computer or phone connected to your router's network.
Enter your router's IP address in the address bar. This is often 192.168.1.1 or 192.168.0.1. Check your router's documentation or the sticker on the device if you're unsure.0 -
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
