logging
Hi all,
I notice when i open the logging of the nebula firewall (usg flex 200), i just see one kind of entry:
Received IGMPv3 Join message on Group:
and this one 900 times.
Off course i can search for other entries. But i just want to see all entries. I don't care about the igmpv3 messages. In other way can i disable igmpv3 log messages?
yours, dennis
Hi @Dpj,
Could you take a screenshot of the entire log with us? Then I can help check for a way to disable it.
By the way, is this firewall running Nebula mode or Nebula monitoring mode?
Zyxel Melen0 -
hmm i just noticed now there are soooo many of this messages (al the same timestamps).
is that normal behavior? It seems it's an sonos sound system.
Hi @Dpj,
Thanks for the screenshot. I did a quick check, but I'm unsure which log setting should be disabled to not record the IGMP logs. I'm checking with our engineer and will update you once I get further information.
Zyxel Melen0
- 603 USG FLEX H Series
- 480 News and Release
