Nebula Access Point Secondary DNS
andppa
andppa Posts: 1 image  Freshman Member
Hi guys,
in the Nebula Access Point network configuration is not possible to assign a static IP as secondary DNS server and setting up the network using DHCP the access point gets only a primary DNS server.
I hope, soon as possible in the new firmware release we can setup a secondary DNS server.
Obviously nowadays if the first DNS server is unreachable, clients connected to the access point won't work correctly.
Best Regards,
Andrea
2 votes
Active · Last Updated
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,330 image  Zyxel Employee
    Hi @andppa ,
    Thank you for your suggestion. We will carefully evaluate this feature.
    In the meantime, we recommend using a known DNS server, such as Google Public DNS (8.8.8.8 or 8.8.4.4), to help maintain a stable wireless connection.
    Zyxel_Judy
    Untitled Image
  • jpblanch75
    jpblanch75 Posts: 185 image  Master Member
    First Comment Friend Collector Third Anniversary Community MVP
    I 2nd this.... Should be two options. I've never seen a network device limited to one option.
    PeterUK Posts: 4,437 image  Guru Member
    edited April 2025
    Hmm its like that for standalone too but this is only for the AP not devices connecting through it so not too bad if the AP can't DNS?
  • SarpeTronic
    SarpeTronic Posts: 2 image  Freshman Member
    There is still only one DNS, even when using DHCP, this is not ok for that price. You eather want to promote a professional product, or you work with public IPs, for a low quality product.
Nebula Tips & Tricks
