need interface rate limiting
2»
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @PeterUK ,
    I did try using BWM for interfaces WAN1 and DMZ that are in a bridge and it did not rate limit that way
    Is the issue that the BWM feature isn't functioning properly with your current settings, or that you're unable to configure different bandwidth limits for each individual interface as you need to?
    Zyxel_Judy
    Untitled Image
    PeterUK Posts: 4,268 image  Guru Member
    edited February 27
    Both but I'm saying to look at just BWM this does not rate limit set at 1Mb download and upload where DMZ and ge1 are in a bridge
  • Zyxel_Judy
    Hi @PeterUK ,
    Thank you for your input. We will continue to monitor the user's requirements and evaluate this.
    Zyxel_Judy
    Untitled Image
    So in V1.32 you have remove being able to add interfaces of a bridge in BWM but my old test rule was still showing up and it did limit from DMZ to ge1 download 1Mb but not the upload so I hope to see being able to do this in the future along with total interface limiting.
