Option to disable WMM
I personally don't like using WMM and it would be great to have an option to disable it in Nebula.
Hi @jpblanch75 ,
Could you please share why you prefer not to use WMM? Are you experiencing any specific problems with the default enable WMM on Nebula? Understanding your concerns will help us better address your request.
Zyxel_Judy
For one some devices such as Apple recommend disabling WMM for AirPlay to function properly.
Most homes now have plenty of bandwidth that using WMM is useless. An option to disable it in Nebula would be great. Standalone give multiple WMM options including disabling it.
Hi @jpblanch75 ,
On Nebula AP, WMM is enabled by default with the traffic type set to "best effort." While we are considering adding functionality that would allow users to select different WMM options in Nebula as in standalone mode, completely disabling WMM will not be an available option.
Zyxel_Judy
- 441 Beta Program
- 292 Service & License
