V1.32 500H: the logs are broken
The logs are broken even with 1.32 firmware
Hi @Mk88_it ,
We've identified and resolved the issue where some settings were not written fully into the configuration file that were preventing event logs from being generated, which also caused the 'Log Setting' page to fail to load properly.
Please monitor to confirm the logs is working correctly. If you encounter this problem again, we would appreciate if you could provide us with the specific steps that you think led to the issue, as this would help us reproduce and address it more effectively.
Zyxel_Judy
Hi @Mk88_it ,
Zyxel_Judy
Hi @Zyxel_Judy thanks for your immediate support.
I don't fully understand your explanation, especially when you say "some settings were not written fully" 🤔….. but ok.
I'll monitor the situation and let you know if this problem appears again.
Anyway, I want to clarify that I didn't do anything that could cause the problem. I just configured the HA feature and didn't make any other changes to the system after the 1.32 firmware installation
- 591 USG FLEX H Series
- 478 News and Release
