Option to disable WMM
jpblanch75
jpblanch75 Posts: 185 image  Master Member
First Comment Friend Collector Third Anniversary Community MVP
I personally don't like using WMM and it would be great to have an option to disable it in Nebula.
1 votes
Active · Last Updated
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,330 image  Zyxel Employee
    edited April 2025
    Hi @jpblanch75 ,
    Could you please share why you prefer not to use WMM? Are you experiencing any specific problems with the default enable WMM on Nebula? Understanding your concerns will help us better address your request.
    Zyxel_Judy
    Untitled Image
  • jpblanch75
    For one some devices such as Apple recommend disabling WMM for AirPlay to function properly.
    Most homes now have plenty of bandwidth that using WMM is useless. An option to disable it in Nebula would be great. Standalone give multiple WMM options including disabling it.
  • Zyxel_Judy
    Hi @jpblanch75 ,
    On Nebula AP, WMM is enabled by default with the traffic type set to "best effort." While we are considering adding functionality that would allow users to select different WMM options in Nebula as in standalone mode, completely disabling WMM will not be an available option.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
