Jason
[NEBULA]where i found the firmware for manual update of switch NSW Total Series? Thnak You very Much
good evening, I wanted to know if it was possible to manually update the firmware of the
NSW100-10 and NSW100-10P and NSW100-28p switchs devices; From the NCC Console it cannot complete the total
firmware update but remains partial in orange; I don't understand why it's not possible,
find the firmware and do the manual update like the traditional zyxel switches. Thank you.
Andrea Sdringola
Hi @AndreaSdringola,
I will PM you for detail information later.
Please help to check you Forum Inbox.
Thanks.
I'm having the same issue w/ an NSW100-28P. Can you please advise how I can upgrade the switch manually?
Thanks in advance,
TJ0 -
FYI to anyone who may encounter the same issue - this was resolved with a manual firmware update via the local web UI of the switch.0
Hi All,
Generally if your device shows partially done, need firmware upgrade, please go to firmware management page to upgrade device FW.
However, for specially cases that firmware upgrade cannot be perform, please feel free to contact Zyxel support any time.
Hope it helps.
Jason0 -
Good morning, actually a big thank you to Jason, because thanks to the firmware,
his help and manual action it was possible to completely solve the problem.
Thanks Jason.
3 -
I found the firmware upgrade page in the Site-Wide - Configure - General Settings of the Nebula Control Center, not the on the Switch page as it seems to show above. From there, you can choose to 'perform the upgrade now' and it will perform the update for you.
Hope this helps someone else
2 -
I'm having the same issue w/ an NSW100-10. Can you please advise how I can upgrade the switch manually?
Hi @foxxp ,
To have more details to identify the issue you have, I will PM you for more information.
Please help to check your Forum Inbox.
Thanks.
Jason0 -
I need a manual download of the latest Firmware too, dusted off a NSW100-24 running V2.00(ABBT.3) and it won't update via NCC! @Nebula_Jason
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
