Is there a way to remove one of the test services that came in a standard 30 days test version?
wolfman
wolfman Posts: 5 image  Freshman Member
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @wolfman ,
    Could you please share with us the following information:
    • The device's MAC address
    • Security pack name
    • The specific service you want to remove
    • Your reason for wanting to remove this service
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @wolfman ,
    The entire GSP trial Pack has expired as you request.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @wolfman ,
    Zyxel_Judy
    Untitled Image
  • wolfman
    edited April 16
    The security pack I want you o remove is obviously the Web filtering servixe which prevents me from accessing my internal html pages because it classifies them as being unsecure. The name of the service that pops up is Trellix.
    So please remove this thing - I don't want to switch back to my old USG40 and wait until the test period to this unwanted servie has finally expired.
    — MAC address & SN number are removed by Zyxel agent—
    Many thanks in adavance.
    Wolfgang Schiketanz
  • Zyxel_Judy
    edited April 18
    Hi @wolfman ,
    The Web Filtering license applies to the Web Content Filter and DNS Content Filter functions. This license is unlikely to be causing the issue preventing access to your internal HTML pages.
    We recommend checking other settings related to your internal HTML pages first.
    If you still wish to remove the trial Web Filtering license, please confirm, and we will proceed with implementation.
    Zyxel_Judy
    Untitled Image
  • wolfman
    Disabeling all the content filters did not change anything. Then I switched back to my old USG40 and it works there without any problems. So please remove the web filtering service - I hope that this will resolve the issue.
  • Zyxel_Judy
    Hi @wolfman ,
    We would like to inform you that it is not possible to terminate a single service individually. The only option available is to terminate the entire GSP trial Pack.
    We would also like to help you investigate the issue regarding your inability to access your internal HTML. Please share the following detailed information with us:
    • Your network topology related to your USG FLEX 100, your end client, your internal HTML setup. Information on how your devices are connected, the IP addresses and other relevant configuration details.
    • The exact error message you receive when attempting to access your internal HTML, providing the screenshot if possible.
    Additionally, please enable WAN access to facilitate our investigation.
    Zyxel_Judy
    Untitled Image
  • wolfman
    Due to Easter holidays I am pretty busy right now. But it would be great if we could start by removing this unwanted test versions. I don't want them and I don't need them either and I would never consider buying any of those services. They are just making my life more complicated. I am currently using a Mozilla VPN to bypass all that. It slows my download speed but at least I can move around freely.
    You asked me for my setup. It is very simple: Just one PC hooked directly to the routher and a Zyxel5 WLAN setup on a second port.
    Kind regards
  • Zyxel_Judy
    Hi @wolfman ,
    Zyxel_Judy
    Untitled Image
  • wolfman
    Thank you. Now everything runs perfectly as it should.
Service & License Help Center
