Zyxel 1200-8 Firmware upgrade
I just got a Zyxel 1200-8 POE v.2 switch and I am trying to update the firmware to version 2.00. When I enter the firmware upgrade page and click path to select the firmware, it populates the text box with C:\fakepath\firmware_name and fails when I click update. If I type the path and name of the firmware and click update it does nothing. I have tried multiple browsers and paths and it never works. How do I update to the latest firmware?
HI @Mr_Wrong,
Welcome to ZYXEL community.
In order to solve your issue, I would like to ask questions as below:- May I know if your device is GS1200-8HPv2 ?
- Were you use the V2.00(ABMF.0)C0.bin file to upgrade? Kindly remind the download file need to be unzip before upgrade.
- If you still have same problem, you may try the hotfix version which we fixed an issue related to management vlan. The link is following: https://community.zyxel.com/en/discussion/9591/fixed-gs1200-8-8hpv2-management-ip-address-issue#latest
Hope it will help.Zyxel Melen0
HI @Mr_Wrong,
Hope it will help.Zyxel Melen0 -
Hi, thank you for your reply. I am trying to update a GS1200-8HPv2. I did unzip the file and attempt to update using the GS1200-8_V2.00(ABME.0)C0.bin file.
I downloaded the files from the other link that you sent but the problem is that when I browse to select the file it always shows up as <drive_letter>\fakepath\<firmware_name>. However, this time when I placed it at the root of my drive and typed in the path and updated, it worked. That did not happen with the other firmware. I've included a screenshot of the issue I was having below. It shows what was populated in the Firmware path after I selected the file at the root of my C: drive. I tried edge, chrome and firefox all had the same issue.
Thanks for the help!0 -
I have this problem, too. Are you kidding me? If I type in the correct path manually and hit Upgrade, exactly nothing happens. I'm on a Mac using Safari, my Zyxel GS1200-5HP v2 is running V2.00 (ABKN.1)C0 (yet).
Hi @Mediamaster,
I did a local test with MAC and Safari (V18.4(20621.1.13.11.3)) to upload the firmware file to the GS1200-8. The result was success. The browser behavior looks like nothing happens; the countdown was kept at 40 seconds remaining. However, the MAC actually send/upload the firmware to the switch. After the firmware file uploading finishes, my GS1200-8 reboots and applies the new firmware. If your switch didn't reboot after 40 seconds, please try other browsers like Google Chrome or Edge. Hope this helps.
Zyxel Melen0
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 270 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
