Switch XMG-108 and XMG-108HP
I have 4 of these switches connected in series. The LEDs indicate LOOP between them. The network works. I tried connecting the switch to the switch with a cat7 cable and a 10gbe optical cable and it still indicates a loop (the green LED blinks slowly)
even if I connect two switches to each other and nothing else is connected, it automatically indicates a loop.
Is this normal?
I haven't found anything about it anywhere.
Thanks, who knows what it is.
So the engineers must have made a mistake somewhere. Never mind, it works so I'll leave it at that.
Thank you for your answer :)
Hi @server3,
This is a known issue in the XMG100 series. It enables loop detection but accidentally recognizes the loop probe packets from other XMG100 series as from itself when the XMG100 series connects.
The traffic will be forwarded without issue since this is the loop detection behavior.
Zyxel Melen0 -
Update:
This issue has been fixed in the newly manufactured device. You may check if your serial number is after the serial in the below table.
Model
SN from
XMG-105
S244322003111
XMG-108
S244328017995
XMG-105HP
S244318000001
XMG-108HP
S244318000501
Zyxel Melen0 -
(double post deleted)
Is there a way to update/replace existing devices that exhibit this issue?
Hi @BernhardS
You may apply RMA request to get a replacement.
Please reference this FAQ to submit RMA request:
Zyxel Melen0 -
I started this thread a while ago with this problem.
I asked the seller for a replacement and there was no problem with it. They sent me other devices. The newer ones also have flow control button.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
