Problem with WX3100-T0 unit
RxFNL
RxFNL Posts: 4  Freshman Member
edited April 21 in Home Router
Hi, I have 2 WX3100-T0 units, one of then has an old firmware version V5.50(ABVL.2.1)Y0 and I need to update it but when I go into Maintenance, firmware upgrade is not there. can anyone help please.
  • Liba
    Liba Posts: 202  Master Member
    First Comment First Answer Second Anniversary
    I think you need to contact the store where you got the WX3100 for assistance.
  • Liba
  • RxFNL
    Thanks, but got it off ebay and it is stamped with an ISP logo that I don't use. Is there any why of over riding the software that is on board? Many thanks
  • RxFNL
    Hi, now have a new wx3100-t0 with up to date firmware. Question is How to create a daisy chain from another wx31000-to. So I have a DX3301-T0 router and a WX3100-T0 device working in RP mode but it's not reaching the wifi device I need to control, therefore I need to daisy chain another WX3100-T0 device from the one that's working but I don't know how to do it. any help would be most helpful.
