supervisor/root and admin password of my NR7303
8black888
I'm need the supervisor/root and admin password of my NR7303.
S/N is S240Z29003300
Can someone help me please?
Many thanks.
Hi! For security reasons, default supervisor/root and admin passwords are usually provided in the device manual or on a label under the router. If they've been changed and you don't have them, the best option is to perform a factory reset (hold the reset button for ~10 seconds). This will restore default login credentials. After resetting, try:
- Username: admin
- Pwd: 1234 (or blank)
If that doesn't work, contact the support with your serial number for verified assistance.
- 428 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 348 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 404 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
