FWA505 bridge mode
MattiS
MattiS Posts: 9 image  Freshman Member
Hello!
How do I put the wan port in bridge mode, so that the firewall gets the ip address straight from isp?
  • Peter2
    Peter2 Posts: 176 image  Master Member
    You can change in the braoadband section from Routing to bridge mode if your firmware is not provider restricted and allows this . The rest is to configure your firewall device behind the router to set up the connection .
    edited April 2025
    Use Cellular IP Passthrough
    note some Cellular providers don't give you the WAN IP and or by CGNAT
  • Peter2
    Nearly the same according to this article :
    https://support.zyxel.eu/hc/en-us/articles/360021412820-NR7101-FWA710-How-to-set-bridge-mode-cellular-IP-passthrough
    "Bridge mode is also called cellular IP passthrough on many Zyxel LTE devices. This article will teach us how to set your NR7101 / FWA710 to bridge mode.
    Please note that the default mode will be "Routing Mode / NAT Mode.""
