Direct Support ticketing function travels through Organizations
GiuseppeR
GiuseppeR Posts: 661 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
as you open more Organizations inside Nebula, so having more tabs open each with a different Organization, could cause interference when opening a ticket from Direct Support area:
I opened OrganizationA and its support request lists (I needed to copy a previous similar Case reference).
After that I opened another tab with OrganitazionB to look into its tickets too.
So from tab (just ready) on OrganizationA I opened a ticket, explaining the issue, selecting also the right hardware having issues.
The result is that I have a Case opened in OrganizationB also if I used the other tab with OrganizationA.
Please refer to Case 241001856 (right Organization) and Case 241001847 (wrong one).
You can see also the mistake made by Direct Support with a Case open with null value as hardware (241001847)
While you can see the right one (241001856):
  • Zyxel_Kay
    Hi @GiuseppeR
    After reviewing this case, we’ve identified a bug affecting this function. When multiple tabs are open, the organization/site shown in the support ticket corresponds to the last tab opened rather than the active Nebula organization/site in each respective tab.
    We're actively working to resolve this issue and will keep you updated with any progress. Thank you for your patience and understanding.
    Kay
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @GiuseppeR,
    This issue has been fixed. Please help to check if this issue happens again in future.
    Zyxel Melen
  • GiuseppeR
    Hello @Zyxel_Melen
    thanks a lot for your notification, if needed I'll update you about that issue in the future.
    Have a nice day
Nebula Tips & Tricks
