2 AP stopped working with GS1900-24EP
Two of my access points (Unifi) have no internet when plugged in to the switch GS1900-24EP. It used to work just fine. I have three more AP's that works fine with the switch.
How can I fix this problem?
Information:
Switch: GS1900-24EP
Firmware: 2.7.3
My AP's have worked perfect for years with the switch.
The AP's works great if plugged into the router (no switch).
I have reset the AP's.
POE power and cables is not a problem.
It does not matter if I change the port and cables.
When plugged into to the switch I will get internet for about a minute and then it "shuts down" (no or super slow internet).
The AP have the right MAC address and I can't see any duplicates in the switch web UI (MAC table).
The port status is, State: Enable, Up, Auto-1000M.
Any ideas?
Hi @SwitchAnon,
Could you upgrade the switch firmware first since it is not the latest one? Firmware link
If this issue happens again after firmware upgrade, since you changing ports/cables are still the same, please help download the tech support log and share it with me in a private message.
Zyxel Melen0 -
I did upgrade the switch to the latest firmware and rebooting. And it dit not working. I have send you a log file.
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 355 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
