Zyxel VMG4005-B50A re-connection problem
Sergi330
in Home Router
I use the VMG4005 in bridge mode with TIM FTTC and I have, currently, a slightly unstable line.
When the modem loses the connection it does not reconnect automatically, I have to turn power off and on again to get back online.
With the TIM modem I do not have this problem (sure, the small interruption of connection remain, but after a few minutes it reconnects.)
What settings can I change to prevent this?
Currently it is configured like screenshot attached.
and the others settings are the default.
Thanks!
For me, it seems to be the conneciton is ok, in the beinngin. I would suggest to check with your internet service provider to see why there is sudden disconneciton and if possible the DSLAM does re-train or not. hope this help.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
