NWA50AX REPEATER WIFI NO LAN
aangeloni
aangeloni Posts: 1 image  Freshman Member
edited May 2025 in Nebula
Good evening, I would like to know if the NWA50AX product can be used as a smart mesh wifi repeater like the NWA55AXE model. THANK YOU
I WOULD NEED TO CONNECT IT WITHOUT LAN
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @aangeloni ,
    All Zyxel access points, including the NWA50AX, can function as repeater APs via wireless connection using Smart Mesh technology. It means without requiring a LAN cable for the mesh uplink connection.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @aangeloni ,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
