Cannot connect to NXC2500 via 192.168.1.1
Hi @fgssg
I suggest connecting to the device via the console port.
You can get more information in chapter 3 of the Troubleshooting guide:
https://support.zyxel.eu/hc/en-us/article_attachments/360000446579/WLAN_TroubleshootingGuide_Edition_1.pdf
Regards
2 -
Hi @fgssg
NXC management interface doesn't provide DHCP server function, maybe you can setup static IP on your NIC which is in the same subnet and VLAN as NXC, and then try again. (Ex: IP.addr = 192.168.1.3, Subnet Mask = 255.255.255.0, Default gateway as blank)0 -
I agree that connect the console to NXC and reboot NXC again. Check if there are some error message show on....Alfonso said:Hi @fgssg
Regards
connect the console cable is the fast way to check the NXC status.
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
