Cannot connect to NXC2500 via 192.168.1.1
fgssg
Posts: 5 Freshman Member
I cannot connect the NXC2500 to my computer via 192.168.1.1 even after I reset the unit. I tried from port 1 to port 6.
Error message :
Error message :
This site can’t be reached
Hi @fgssg
I suggest connecting to the device via the console port.
You can get more information in chapter 3 of the Troubleshooting guide:
https://support.zyxel.eu/hc/en-us/article_attachments/360000446579/WLAN_TroubleshootingGuide_Edition_1.pdf
Regards
2 -
Hi @fgssg
NXC management interface doesn't provide DHCP server function, maybe you can setup static IP on your NIC which is in the same subnet and VLAN as NXC, and then try again. (Ex: IP.addr = 192.168.1.3, Subnet Mask = 255.255.255.0, Default gateway as blank)0 -
Alfonso said:Hi @fgssg
Regards
connect the console cable is the fast way to check the NXC status.
- 397 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 52 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 72 About Community
- 63 Security Highlight
