Where is all the documentation for SecuExtender?
I bit the bullet and bought licenses for MacOS and Win11.
I use the StrongSwan for Android and the Win11 clients and settings created by the Zyxel firewall wizard, and they work automatically just fine.
Now, I need to know where to look after what on the firewall, in order to configure the SecuExtender VPN client.
Where is all the documentation for it?
Thanks, somewhat :) as I do not use Nebula. But I got some ideas to try first.
Thanks again…. so, the IPSec works fine still from Android and StrongSwan, and it works fine with the native Windows IPSec VPN - but only from trusted networks.
This is why I bought SecuExtender, to have another dedicated executable to let through instead of allowing native standard windoze .dll's etc to communicate via untrusted networks instead of being blocked of doing so in untrusted networks.
Now, I just seem not to be able to download the provisioning from the firewall which has been already configured and functioned with IPSec, to the SecuExtender client app.
How can I create and download this .tgb file directly from my USG firewall?
Question: when I am on my local network, can I request the configuration via the VPN Configuration Server Wizard?
Where on the firewall can I get the Firewall ID and the Client ID? or, what needs to be entered there?
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 293 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 263 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
