Where is all the documentation for SecuExtender?
I bit the bullet and bought licenses for MacOS and Win11.
I use the StrongSwan for Android and the Win11 clients and settings created by the Zyxel firewall wizard, and they work automatically just fine.
Now, I need to know where to look after what on the firewall, in order to configure the SecuExtender VPN client.
Where is all the documentation for it?
Thanks, somewhat :) as I do not use Nebula. But I got some ideas to try first.
Thanks again…. so, the IPSec works fine still from Android and StrongSwan, and it works fine with the native Windows IPSec VPN - but only from trusted networks.
This is why I bought SecuExtender, to have another dedicated executable to let through instead of allowing native standard windoze .dll's etc to communicate via untrusted networks instead of being blocked of doing so in untrusted networks.
Now, I just seem not to be able to download the provisioning from the firewall which has been already configured and functioned with IPSec, to the SecuExtender client app.
How can I create and download this .tgb file directly from my USG firewall?
Question: when I am on my local network, can I request the configuration via the VPN Configuration Server Wizard?
Where on the firewall can I get the Firewall ID and the Client ID? or, what needs to be entered there?
You can use "get from server" to directly download the script to your SecuExtender.
Please refer to this aritcle:
Thanks for the reply.
I have an USG-20W-PN, no series H. As I cannot connect remotely from Win11, because I do not have the configuration for the SecuExtender client (duh), will try to download the config when in LAN.
USGFLEX/ATP standalone mode also work with this feature.
please make sure this option is enabled.0 -
Do the above instructions work also for USG-20W VPN series?
Do both SSL VPN and IPSec VPN work with SecuExtender latest versions and USG-20W-VPN as well?
Do both work for MacOS and WIn11 clients?
Lots of questions :)
- 603 USG FLEX H Series
- 480 News and Release
