WIFI Whatsapp calls
FabrizioF
FabrizioF Posts: 8 image  Freshman Member
Hi, can you help me to find the best configuration for Whatsapp calls with WIFI?
  • USG FLEX100W (WIFI OFF)
  • NWA90AX
thanks in advance
Fabrizio
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,244 image  Zyxel Employee
    edited May 15
    Hi @FabrizioF,
    I would like to clarify with you some questions:
    1. What issue did you encounter when having a WhatsApp call with Wi-Fi?
    2. What mode is your firewall and AP? On-premise? Nebula?
    3. Are these devices upgraded to the latest firmware?
    4. Did you try to call others when using the same Wi-Fi?
    Zyxel Melen
  • FabrizioF
    1- the voice skips, it is heard in fits and starts
    2- Nebula
    3 yes , last firmware
    4 - yes, random, not always with the same people
  • Zyxel_Melen
    Hi @FabrizioF,
    Thanks for the information. Could you help to record issue timestamp, issue client's MAC address, and enable Zyxel support access so we can help to investigate what could be happened when this issue occur?
    Zyxel Melen
