security policies
Another think with security policies…
When i change the order of de rules, you change the positions of the rules. for example, when i want rule 8 between rule 1 and two…, I move it on top of rule 2, but what hapens then… rule 2 moves to rule 8, and the former rule 8 is on position 2.
So then i have to move 8 to 3, next 8 to 4, 8 to 5, 8 to 6, 8 to 7 and then i'm finished.
It would be more logic, when i move 8 to 2, all the rules moves 1 position down.
yours dennis
Thanks for your feedback, we will adjust the rule order movement behavoir.
Do you know when this will be arranged? (i thought it was allready arranged, but it isn't i found out)
Hello @Dpj @Zyxel_James @Zyxel_Melen
I would like to add also another problem with rules' order that has huge differences from on prem config:
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 300 Service & License
- 483 News and Release
