Problem to connect ftp with 1990 port - USG Flex 100
Gru_Ma
Gru_Ma Posts: 10  Freshman Member
Hello
i'm try to connect an ftp server with port 1990 but not works. It works with statandard port and works if i connect form other lan not connect to firewall
I not set any limitations form lan to wan
  • Zyxel_James
    Zyxel_James Posts: 745  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Could you please clarify your scenario in more detail? please also explain your network topology, thanks.
    So it works with port 21 when the traffic is not passing through firewall. then why you want to access by port 1990 to a FTP server?
  • Gru_Ma
    Hello
    Thanks for your reply.
    If i try to access  with port 21 when the traffic is passing through firewall it works
    If i try to access  with port 1990 when the traffic is passing through firewall it not works
    If i try to access  with port 1990 when the traffic is not passing through firewall it works
    PeterUK Posts: 3,776  Guru Member
    edited 7:57AM
    Does the FTP server support both Active and Passive?
    If Passive only you will need to allow outgoing for TCP ports other then 1990 or allow rule for the IP of server
    If Active only you will need to allow incoming for TCP ports or allow rule for the IP of server
    with port 21 ALG takes care of FTP
