Problem to connect ftp with 1990 port - USG Flex 100
Could you please clarify your scenario in more detail? please also explain your network topology, thanks.
So it works with port 21 when the traffic is not passing through firewall. then why you want to access by port 1990 to a FTP server?0 -
Hello
Thanks for your reply.
If i try to access with port 21 when the traffic is passing through firewall it works
If i try to access with port 1990 when the traffic is passing through firewall it not works
If i try to access with port 1990 when the traffic is not passing through firewall it works
Does the FTP server support both Active and Passive?
If Passive only you will need to allow outgoing for TCP ports other then 1990 or allow rule for the IP of server
If Active only you will need to allow incoming for TCP ports or allow rule for the IP of server
with port 21 ALG takes care of FTP
Hello
i had set a new policy
But not works
I'm try to connect from my lan to external ftp server
Due to how FTP works in Passive mode you have the control port 1990 and a range of DATA ports all of which is outgoing LAN to WAN
In FTP Active mode you have the control port 1990 which is outgoing and DATA port incoming WAN to LAN.
Try with a IP or FQDN
Not tried it but if you put 1990 in additional FTP signaling port that should work
Hello
i have already tryed but not works. Thanks
I also would like to know the FTP mode is active or passive, and what's the data port and command port.
Or you can simply have a test to determine if the security policies are the reason the FTP access get blocked, that is, disable Policy Control.
Moreover, Is your USG FLEX 100 behind NAT?0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
