WAX610D in smart mesh mode and LAN-output
Hi there
I use three NWA1123-AC V2, managed through Nebula. As of now one NWA50AX Pro is connected wirelessly through Smart mesh to a NWA1123-AC V2. I would like to connect a Raspberry Pi via Ethernet to the NWA50AX Pro, however I read, that this (LAN-bridge) is not possible through Nebula.
After research and consulting Chat GPT a WAX610D could help.
question #1: Can I manage and connect a WAX610D wirelessly through Nebula and use Smart mesh to connect the WAX610D to my existing APs NWA1123-AC V2?
question #2: Can I use the LAN1-port on the WAX610D to then connect the Pi via Ethernet?
I could not find a clear answer on my usecase, hence the question.
Kind regards,
Andrew
Hi @Wookie
Question #1: Yes, you can.
Question #2: Yes, you can connect the Pi to the LAN 1 port of WAX610D with the wireless bridge function enabled. The wireless bridge function is in the device detail page.
Zyxel Melen0
Hi @Wookie
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
