FWA710
Unit speedtest shows speeds of 191.67mbits download but i only get 20ish mbps via the lan cable.
am i missing something? ive tried the 3 different firmwares on the website and, laptop/mikrotik routers. nothing seems to be able to get the speeds the unit claims it can do. im so confused. am i missing something?
Hi @manners,
To better clarify this issue, may you share your topology? Your issue is that the LAN device can only get 20 Mbits but not the same as device speedtest result?
Zyxel Melen0 -
Its a fwa 710 on ID mobile which i believe is three mobile
Connected directly to a mikrotik 3011 or a laptop
Both show the same kinda speeds unfortunately
Hi @manners,
Since the information you provided is not enough to check. Please help to provide your complite test topology? Below is an example:
And did you test with speed test? Could you share these test results with us?
Zyxel Melen0 -
there is no poe switch just the injector it came with.
i will aim to do more speedtest.net tests over the next few days and post screen shots of the results
Many thanks
- 603 USG FLEX H Series
- 481 News and Release
