ZyWALL 110 routing performance issue
Tattoofreak
Hi
I have a ZyWALL 110 with no UTM services activated.
When copying a single file (about 10GB) between VLANs from one computer to another computer the performance will not go over 45MB/s.
When putting the two computers into the same VLAN so the traffic won't pass the ZyWALL the performance reaches 1Gb/s like it should.
I was not able to find out where the problem is but obviously it's an issue on the ZyWALL.
The ZyWALL 110 is a quad-core 1GHz CPU when you do a file transfer by one thread (192.168.0.2:40000 > 192.168.1.2:80) it will be one core for sending one core for receiving as the ZyWALL can't seem to use more cores on one connection thread. But if you did a file transfer with many threads
(192.168.0.2:50000 > 192.168.1.2:80)
(192.168.0.2:60000 > 192.168.1.2:80)
you use more cores to get a higher transfer speed.
So in general this means there is no way for routing a single file with Gbit/s speed across VLANs with ZyWALL 110?
If your using MS file and printer sharing then no
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
