Difference between XGS1930 and XGS1935
ZYXELSAML
ZYXELSAML Posts: 4 image  Freshman Member
We would like to add a second, similar switch to our current XGS1930. (Replace even older one)
It appears that the XGS1935 is a direct, functionally identical replacement.
Is that correct, or are the XGS1930 and XGS1935 functionally different?
"Lite 3" functions are important to us. And non-cloud management.
Thank you very much for your time and reply.
Best regards.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @ZYXELSAML ,
    The XGS1935 succeeds the XGS1930 with enhanced hardware while maintaining the same functionality, so it can serve as a direct replacement for the XGS1930.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @ZYXELSAML ,
    Zyxel_Judy
    Untitled Image
  • ZYXELSAML
    Thanks a lot, Judy.
    Have a nice day.
    Best regards,
    Petr
