Zyxel DX3301-T0 missing Firmware Update "voice"
2»
  • Marino
    Marino Posts: 12 image  Freshman Member
    I also attach the config files if they can help. There is no private information
  • Marino
    edited May 2025
    blank post for error
  • Peter2
    Peter2 Posts: 176 image  Master Member
    edited May 2025
    I dont have these lines :
    ["DefaultGuiPassword":"",
    "ResetDefaultPassword":false,]
    What happens when you change to ["ResetDefaultPassword":true,] and make a reset ?
    Or delete these lines .
    » But all this is now speculating …
  • Marino
    try both changes. Both 1) change variable and 2) delete variables. Unfortunately nothing changes in the final result.
    I could ask you to create a configuration file yourself. With a user "peter" and password "zyxel2025" with an admin profile. Do export, delete everything else from the config and attach only the user part. This way I will try to do an import adding your mod.
  • Peter2
    Sorry but no . My hint with the user group instead of admin was ok but i dont have enough knowledge about the hole thing . Someone with real expertise would know what happend exactly and how to solve the Problem . May be you can email for support …
  • Marino
    In the end I succeeded in the intent, even if I had to apply great subterfuge. Through various searches on google and studies, I discovered that the firmware version that I had also had a vulnerability (shell code execution from root). I can't post details because I think I'm violating some rights.
    However, having obtained the password from the supervisor, I deleted the admin user and recreated it in the correct group. I also tested that the reset brings the user back to the user group. Finally I also updated the firmware to the latest version available and I have all the functions available.
    I conclude in all of this that I am very sorry for the Zyxel products that apply these limitations. I hope you can understand how much frustration this situation has created.
    Best regards
