SSLVPN for Android OS
Several Hotspots are bocking IPSEC connections, but you are able to connect trough SSL-VPN
Or ... is there a known SSLVPN Client existing with ZYWALL USG devices ?
Regards
Christian
Hi @ChristianG
Currently there is no SSL VPN App for Android or IOS platform.
So I would like to add this topic to idea.
7
Hi @ChristianG
7 -
Is there a thread topic for "long overdue idea" or perhaps "get with the program" ?0
Hi @Paluszak
IOS and Android OS have supported build-in VPN client software.
You can use it to build L2TP VPN tunnel for the same purpose before mobile SSL SecuExtender has supported.
i correct the question as follows ?
is ZYXEL palnning to support 3rd party SSL-VPN (like OpenVPN) to get successful connected?
L2TP is not primaly allowed at hotspots or hotel wifi ? but TLS 1.x is by default allowed ?
Therefore the question concerning SSL-VPN in the background of future, ditigal workplaces and usability on the faforit Operating Systems (Windows/iOS/Android).
Regards
Christian
Quite strange... SSLVPN IS OpenVPN driver. TAP driver, modified by Zyxel. :)
Hi @mMontana
Yes, the virtual NIC TAP-32 have driver signed by Zyxel. It’s only for Zyxel connection.
Says, you cannot establish tunnel via OpenVPN TAP-32 virtual Ethernet adapters
my ISP Firewall served the ready to import OpenVPN configuration to import this to Android/iOS OpenVPN aplication. In this case, no trouble of config issues for estaplishing a SSLVPN ?
So this manufactr to not need any invest to update the SSLVPN software self - only the export options to be usable also for further versions of the SSLVPN.
And SSLVPN is popular by other vendors and not only for iOS/Windows availible ?
Regards
Christian
Hi @Christian
Thanks for information sharing. we will evaluate it in the future if it is beneficial.?
- 588 USG FLEX H Series
- 477 News and Release
