BWM Multiple Priorities
Matthew
Matthew Posts: 24 image  Freshman Member
First Comment First Answer Friend Collector Eighth Anniversary
The H series BWM rules allows for setting a Priority (0-7)as well as download and upload limits. Documentation says that any given BWM rule can use any available extra unused bandwidth. However, it is not clear on BWM conflict resolution. How is extra bandwidth divided between rules of differing priorities as well as rules of the same priority? Round Robin/Weighted Round Robin/something else?
For example, I have 10Mbps of upload bandwidth available.
Rule A: Priority 4, UL Limit 7 Mbps
Rule B: Priority 5, UL Limit 5 Mbps
Scenario 1: Rule A needs 10Mbps and Rule B needs 10Mbps.
I believe Rule A should be given 7 Mbps and Rule B should be given 3 Mbps?
Scenario 2: Rule A needs 10Mbps and Rule B needs 2 Mbps.
Will Rule A be given 7 Mbps (its guarantee), Rule B be given 2 Mbps, leaving 1 Mbps available which is given to Rule A for a total of 8 Mbps?
Now lets change the rules so that:
Rule A: Priority 4, UL Limit 4 Mbps
Rule B: Priority 5, UL Limit 3 Mbps
Scenario 3: Rule A needs 10 Mbps and Rule B needs 10Mbps.
I assume Rule A will be given 4 Mbps (its guarantee) and Rule B will be given 2 Mbps (its guarantee). How are the remain 4 Mbps divided?
Will Rule A get the remain 4 Mbps (for a total of 8 Mbps) since it has higher priority? Or will the remaining 4 Mbps be split equally: 2 Mbps to each (Rule A gets 6 Mbps total and Rule B gets 4 Mbps total)?
Or will it employ some kind of weighting for the extra bandwidth: Rule A gets 3 Mbps and Rule B gets 1 Mbps?
On the USG and Flex series, we could designate a guaranteed bandwidth for a rule plus how much it could use extra (to keep a rule from using ALL of the extra bandwidth). I also believe it employed a Round Robin algorithm to resolve bandwidth contention between the same priority as well as extra bandwidth between differing priorities.
Please give us more information on how this works! Thanks!
    edited May 2025
    The current BWM in FLEX H is lacking vs not H FLEX as there is no way to do total interface (or part of a bridge) rate limiting
    FLEX H BWM/interface limiting improvement — Zyxel Community
    In you first example you will go over your 10Mb limit rule A will want 7Mb and rule B will want 5Mb their is no
    total limit these rules or others to stay under
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @Matthew
    Before answering your question, may I confirm the priority in your rule is Tracffic shaping priority? Or the rule priority?
    This information is important for us to clarify your scenario's result.
    Zyxel Melen
  • Matthew
    Traffic priority.
