NWA55AXE zurücksetzen
Villa
Villa Posts: 1 image  Freshman Member
  • Zyxel_Tina
    Zyxel_Tina Posts: 699 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    edited June 2025 Answer ✓
    Hi @Villa,
    Since the NWA55AXE does not have a reset button, there are two approaches to reset your device to factory defaults.
    • ZON utility
      • Open the ZON Utility and click the Clear and rescan icon to scan for the Zyxel Device you want to reset. image.png
      • Select the device and click the Reset Configuration to Default icon. image.png
      • Enter the administrator password in the Password field on the pop-up screen and click OK to start the
    • Web Configurator of the Zyxel Device Gateway: Use this method if the Zyxel Device is connected to a Zyxel Switch with a Neighbor Reset
      function.
      • Log into the Zyxel switch’s Web Configurator. Go to Monitor > Neighbor, and then click the Restore
      • A pop-up window asks you to confirm that you want to reset the Zyxel Device to factory default. Click
    Zyxel Tina
  • Zyxel_Tina
    Hi @Villa,
    • ZON utility
      function.
    Zyxel Tina
