Organization-Wide Nebula Report Request
henriquev
henriquev Posts: 21 image  Freshman Member
Is there a way to generate a report similar to the "Summary Report" in Nebula, but covering all sites at once—providing a comprehensive view across the entire organization instead of focusing on a single site?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @henriquev ,
    Currently, there is no feature to generate a Summary Report covering all sites in an organization. You can submit this as a feature request in the Nebula Ideas section and specify which type of report you prefer:
    • Statistics from all sites in the organization collected on a single page
    • A multi-page report file with each page showing data for one individual site
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @henriquev ,
    Zyxel_Judy
    Untitled Image
  • henriquev
    hi @Zyxel_Judy thank you for your help!
    I’ve already submitted a feature request.
    Do you know what the easiest way would be to routinely export the Organization Portal CSV? Does Nebula offer any API access for this? Alternatively, is there a way we can set up a routine to send Organization Portal information via email?
  • Zyxel_Judy
    Hi @henriquev ,
    Currently, you can only export the Organization Portal CSV manually from this location.
    For API access to this data or automated email reports, please submit a Nebula idea. We'll monitor the votes and feedback on your post to help determine our product roadmap.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
