How to create certificate and import to Nebula Zyxel
Marines
Marines Posts: 2 image  Freshman Member
I want to create a certificate so that my zyxel router can access via htttps.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,051 image  Zyxel Employee
    Hi @Marines
    I can't figure out what you want to do from your post content. But I want to point out that under Nebula mode, the device local GUI will be limited. Please configure and monitor your device on the Nebula control center.
    In addition, Nebula currently doesn't support import certificate function.
    Zyxel Melen
  • Marines
    I created a certificate using OpenSSL and imported it into Nebula, but my router still cannot be accessed via HTTPS.
  • Zyxel_Melen
    Hi @Marino,
    This setting is to import a certificate that can be used by connected Nebula Access Points in WPA2 authentication. Therefore, this will not apply to HTTPS usage.
    In addition, since your device is controlled by Nebula, the device local GUI will be limited. Please configure and monitor your AP on Nebula.
    Zyxel Melen
Nebula Tips & Tricks
