How to activate SecuExtender VPN
I'm having trouble activating the VPN, It says error code: 70. Upon checking it has a problem with administrative rights on the computer. I checked, and my computer is already an administrator. I'm not the one who bought the VPN and my client sent me a link to install it. Kindly please help me. Thank you
  • Zyxel_Kay
    Hi @TeleCrew
    Failed activation may be caused by the VPN client that cannot access the licensing server to get authorize licensing token. The licensing server FQDN is tgbosa.com
    Please confirm if your network allows outgoing connection to the licensing server.
    Kay
  • jasailafan
    jasailafan Posts: 193  Master Member
    Which secuextender version is installed? IPSec_SSL_VPN_7.7.40.019 for Windows or IPSec_SSL_VPN_3.2.4.19 for macos?
  • hara
    hara Posts: 2
    I've installed the version for Windows.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,431  Zyxel Employee
    Hi @hara,
    I'll contact you in private message for the remote access. Thanks!
  • IT_NBSD
    IT_NBSD Posts: 1
    I have the same activation problem. IPSec_SSL_VPN_7.7.40.019 for Windows
  • TeleCrew
    TeleCrew Posts: 6  Freshman Member
    First Comment Friend Collector Seventh Anniversary
    We have the same problem, what’s the solution? Thx 🙏
  • Zyxel_Kay
    Hi @TeleCrew
    Kay
  • RemonB
    RemonB Posts: 8  Freshman Member
    Same problem here cannot activate VPN tool. Error code 70 also in Administrator mode
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,526  Zyxel Employee
    Hi @RemonB,
    Please help to check:
    1. If the device(PC or laptop) can ping the Internet.
    2. Help to nslookup tgbosa.com on this device. If it can't resolve, please change its DNS server setting to 8.8.8.8
    3. Please check if the uplink device blocks HTTPs to *.tgbosa.com or tgbosa.com. If so, please allow these domains.
    Hope it helps.
    Zyxel Melen
  • RemonB
    1. check
    2. Nslookup tgbosa.com answer:
    Server: home
    Address: 192.168.2.1
    Non-authoritative answer:
    Address: 57.128.54.182
    3. tried on different internet connections(also 4/5G hotspot connection) in the Netherlands
  • RemonB
    Hello, sorry but I think there is something wrong with computer of the client
    because i can activate it on my computer.
