[Release Note] Nebula Security Gateway Series - Patch 7 firmware has been released!
Zyxel Nebula Security Gateway Series
Release Note
May, 2025
Firmware Version on all models
Zyxel NSG50 - V1.33(ABHP.7)
Zyxel NSG100 - V1.33(ABEA.7)
Zyxel NSG200 - V1.33(ABLD.7)
Zyxel NSG300 - V1.33(ABOS.7)
ENCHANCEMENT
- Improved device connection stability with Nebula.
Zyxel Nebula Support
Good morning, I wanted to warn the whole community that if you do the firmware update and you have NSWs, behind the firewall, they are disconnected from the cloud, even if they work standalone; be careful because then you have to downgrade the firmware; I'm just trying to solve the problem now with the Great Zyxel Team. Good work to everyone. Andrea
Update: I thank the whole great Zyxel Team and the Great Chris and , for having solved my problem definitively with the NSG50/100/200 firewalls that no longer communicated with the NSW series switches; Basically the problem is the ISP DNS, before I had Google DNS, (the famous 8.8.8.8 and 8.8.4.4), after the firmware update, in my case, thanks to Chris and the Zyxel team, I had to manually enter the DNS of the service provider of each single firewall on each firewall, now everything is solved! Thanks to the real-time efficiency of Zyxel. Thanks Chris and thanks Zyxel. Andrea
We’d like to take this opportunity to clarify that the firmware update to version 1.30 patch 7 primarily focuses on improving connectivity stability with Nebula. It does not introduce any changes that would affect DNS functionality or cause disconnection issues with downstream switches.
If you have any further questions or need assistance with other devices, please don’t hesitate to report the ticket to the support.😊
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 458 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
