SSLVPN for Android OS
ChrisGer
ChrisGer Posts: 206 image  Ally Member
Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
edited April 2021 in Security
Dear ZYXEL Team,
is ZYXEL planning to provide an Androis - SSL VPN client for USG Devices?
Several Hotspots are bocking IPSEC connections, but you are able to connect trough SSL-VPN :/
Or ... is there a known SSLVPN Client existing with ZYWALL USG devices ?
Regards
Christian
  • Paluszak
    Paluszak Posts: 8 image  Freshman Member
    Is there a thread topic for "long overdue idea" or perhaps "get with the program" ?
  • Zyxel_Stanley
    Hi @Paluszak
    IOS and Android OS have supported build-in VPN client software.
    You can use it to build L2TP VPN tunnel for the same purpose before mobile SSL SecuExtender has supported.
  • ChrisGer
    edited September 2019
    @Zyxel_Stanley
    i correct the question as follows ?
    is ZYXEL palnning to support 3rd party SSL-VPN (like OpenVPN) to get successful connected?
    L2TP is not primaly allowed at hotspots or hotel wifi ? but TLS 1.x is by default allowed ?
    Therefore the question concerning SSL-VPN in the background of future, ditigal workplaces and usability on the faforit Operating Systems (Windows/iOS/Android).
    Regards
    Christian
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Quite strange... SSLVPN IS OpenVPN driver. TAP driver, modified by Zyxel. :)
  • Zyxel_Cooldia
    Hi @mMontana
    Yes, the virtual NIC TAP-32 have driver signed by Zyxel. It’s only for Zyxel connection.
    Says, you cannot establish tunnel via OpenVPN TAP-32 virtual Ethernet adapters
  • ChrisGer
    @Zyxel_Cooldia
    my ISP Firewall served the ready to import OpenVPN configuration to import this to Android/iOS OpenVPN aplication. In this case, no trouble of config issues for estaplishing a SSLVPN ?
    So this manufactr to not need any invest to update the SSLVPN software self - only the export options to be usable also for further versions of the SSLVPN.
    And SSLVPN is popular by other vendors and not only for iOS/Windows availible ?
    Regards
    Christian
  • Zyxel_Cooldia
    Hi @Christian
    Thanks for information sharing. we will evaluate it in the future if it is beneficial.?
