How to create certificate and import to Nebula Zyxel
Hi @Marines
I can't figure out what you want to do from your post content. But I want to point out that under Nebula mode, the device local GUI will be limited. Please configure and monitor your device on the Nebula control center.
In addition, Nebula currently doesn't support import certificate function.
Zyxel Melen0 -
I created a certificate using OpenSSL and imported it into Nebula, but my router still cannot be accessed via HTTPS.
Hi @Marino,
This setting is to import a certificate that can be used by connected Nebula Access Points in WPA2 authentication. Therefore, this will not apply to HTTPS usage.
In addition, since your device is controlled by Nebula, the device local GUI will be limited. Please configure and monitor your AP on Nebula.
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
