MTU Size on NWA130BE
CarstenB
CarstenB Posts: 4 image  Freshman Member
I have a XMG1915-10EP Switch and some NWA130BE Access Points connected to Nebula. My NAS Server is connected with 10GbE Port and configured with a MTU Size of 9000. If my Client (also MTU 9000) connects directly to the Switch everything is working fine. No fragmentation and Jumbo Frames are Working fine.
If I connect my client to the 2.5GbE Port of the Access Point the connection is not working any more until i reconfigure my client to use 1500 MTU.
Does the Access Point only support 1500 MTU Size? Or is there any way to configure that (did not find anything in nebula and even on the ap itselt)
Cheers and Thank you
Carsten
  • Zyxel_Tina
    Zyxel_Tina Posts: 699 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @CarstenB,
    Thank you for reaching out and sharing the detailed information.
    At the time of this writing, our access points including the NWA130BE support a standard Ethernet MTU size of 1500 bytes, and currently do not provide configuration options for MTU size or Jumbo Frame support, either via Nebula or the local web GUI.
    Zyxel Tina
  • Zyxel_Tina
    Hi @CarstenB,
    Zyxel Tina
Nebula Tips & Tricks
