wifi and captive portal
I just recently purchased NWA130BE to use it as access point.
I have Pfsense as main router and switch for the vLan and Poe+
Everything connected and setup including the wifi names vlan and works perfectly for 2 subnet
The issue with my Guest network as i am using captive portal configured on pfsense to login and that's is not working as it,s trying to access the subnet to open portal.domain.com
Any advice how to get it working
Hi @mad_4u ,
To better support you, please share the following information:
- Is your network topology: Pfsense → Switch → NWA130BE - - - wireless clients?
- Is your NWA130BE managed by Nebula cloud or in standalone mode? And the firmware version?
- Did you configure the Guest network SSID through the NWA130BE's local GUI?
- Are you experiencing this issue: wireless clients (laptops, phones, etc.) connect to the NWA130BE's Guest network SSID and can access the Internet directly without going through the captive portal configured on your Pfsense router?
- Does this same issue occur with other SSIDs on the NWA130BE or with wired devices on your network?
Zyxel_Judy
- 439 Beta Program
- 529 USG FLEX H Series
- 330 Security Ideas
- 291 Service & License
- 4.6K FAQ
