SSL VPN simultaneous access
I have successfully configured my zywall to allow ssl vpn users connect remotely.
I granted access to two users and they both connect properly individually.
Problem is that while a user is connected, the other one can't connect (it gets disconnected immediately).
As far as I know usg 20 allows up to 5 ssl users for free.
Is there any kind of limitation on simultaneous access? Or do I have to change something in my configuration?
Thanks!
Thanks!
Hi @Zyxel_Stanley
thank you for your answer, I'm currently using usg20 (non-vpn) so you are right.
I also have another issue on ssl vpn, I'm able to connect and reach the internal ip address of the zywall but I can't see any other device on the remote lan.
I assume a policy route is necessary but it's not clear to me how it has to be configured. Could you help me please?0 -
Please note that I can ping the vpn gateway ip address properly (192.168.200.1). The ssl range I assign is on the same class of the vpn gateway (192.168.200.10-20) while the remote lan is on 192.168.30.0/24.
Please advice0 -
Hi @Pabloit
The function you required should be NetBIOS protocol.
The NetBIOS over SSL VPN tunnel doesn't supported on USG20.
Hi @Pabloit
If you would like to pass Netbios traffic over SSL VPN tunnel, you can consider upgrade to USG20-VPN.
- 588 USG FLEX H Series
- 476 News and Release
