Speed Test on USG FLEX 200 via Nebula
I would like to know if it is possible to run an internet speed test on the USG FLEX 200 through Nebula. If not directly via the platform, is there a way to perform it using SSH or HTTPS access?
So far, even when connecting directly to the firewall, we’ve only been able to run basic network diagnostics such as ping and traceroute—no full internet speed tests.
If this feature is currently unavailable, is it on the roadmap? As far as I know, the non-Nebula version of the USG FLEX 200 includes a built-in speed test.
EDIT: I have corrected the device info.
Hi @henriquev ,
For USG FLEX devices managed through Nebula, there is no speedtest tool available in either the Nebula portal or the local GUI. You can use this CLI command instead:
Router> debug _speedtest-cli
Zyxel_Judy
The USG200 is very old and EOL the FLEX200 has speed test option
Indeed, our device is the USG FLEX 200. However, when using Nebula, the device does not have the same GUI as shown - it features a much more limited interface.
@Zyxel_Judy can you help us with this issue?
To be clear, this is our USG FLEX 200 GUI when using Nebula. There is no speed test option.0 -
Hi @henriquev ,
Zyxel_Judy
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
