Sign-In Entra ID Wifi
IT_Connection
IT_Connection Posts: 2  Freshman Member
First Anniversary
I'd like to activate SSO for sign in via Entra for an SSID, I have a NW210AX and I'd like to make sure it's compatible with it. But I haven't found any documentation that explicitly lists compatible wifi terminals.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,556  Zyxel Employee
    Hi @IT_Connection,
    NWA210AX doesn't support Captive portal with Microsoft Entra ID(Azure AD) function.
    Please consider our WBE/WAX series AP models, these models support this function.
    You may also check the device support function on Nebula device function table.
    Zyxel Melen
Nebula Tips & Tricks
