HA configuration on Nebula for FlexH series
GiuseppeR
GiuseppeR Posts: 505 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I installed latest firmware for H series and I see this section on prem:
is there any plan to have this config available on Nebula?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,938 image  Guru Member
    Hi @GiuseppeR,
    After checking, we currently don't have a plan to implement HA configuration on Nebula, as the HA setup requires on-site presence for complex actions. From our perspective, if the device is offline during the actions, this may cause the HA configuration to fail and other issues. Based on the above reasons, we decided not to have the HA configuration on Nebula.
    Zyxel Melen
  • Zyxel_Melen
    Hi @GiuseppeR,
    Zyxel Melen
Nebula Tips & Tricks
