Issues Nebula?
Dpj
Dpj Posts: 187 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
I just found out i cannot login into nebula. As well with edge as Chrome. Fill in username and password, and then an circle, an after 15 seconds, i come back to username and password instead of OTP code
  • Dpj
    i can log in again. Don't know if you changed something. but is seems solved.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,938 image  Guru Member
    Hi @Dpj,
    I tried to login to Nebula after about 30 minutes you posted this issue and there was no issue. I will check with our team if there was any issue during that time.
    P.S. You may try InPrivate mode to see if you can login in the future when encounter this issue.
    Zyxel Melen
Nebula Tips & Tricks
